  1. I use Adobe premeire 5.1LE...
    I am trying to make a slideshow with multiple images and multiple audio clips (eventually a sound mix)...
    I wanted to know with this 5.1LE, how can I make it so images don't show up and STRETCH THEMSELVES to the full resolution? Whenever I import a pc it seems to just stretch FULL SIZE even though the resolution is much smaller than the (FULL IMPORT PIC SIZE)....in other words it stretches the LOW RESOLUTION( or any resolution thats not full screen to FULL screen once i VIEW the SLIDESHOW.
    How do I make it so it just displays the size of the image on a COMMON BACKRGOUND as oppoed to stretching the IMAGE?
    any help would be great thanks
    -Nikos
  2. Hey:
    If you right-click on the clip (the clip in this case is probably an image with a duration of x seconds) there is an option for maintain aspect ratio or something like that. I'm not in front of my editting pc right now, or I'd check it, but look around that right-click menu, and you'll find it.
    Good luck.
    -D
  3. I actually figured that out last night, but I realized since this is a Limted Edition I can't do very much with it.
    Does anyone know any other programs I can get like this that have the options of a TIMELINE< time shifting and captions?
  4. E-mail me, I think I can help you out. kickbxn5@aol.com
