I have a file here that is a .mpg file in SVCD format. I am wondering if there is a way I can convert it to either an avi in vcd and then back into an .mgp to burn, or to actually convert the file straight to VCD, to be able to play on my VCD player. Thank you,
murf
Results 1 to 10 of 10
http://www.vcdhelp.com/mpeg2tovcd.htm Plain as day
Panasonic DMR-ES45VS, keep those discs a burnin' -
i feel for ya .. most of these people cant tell the difference betweena vcd or svcd .. anyhow heres how to REALLY do it ..
1. tpmg (or whatwever its called)
load the svcd template
load file mpeg
under settings select 3:2 pulldown (it is better so all those who say no .. just try it before you squawk!)
hit start and find something to do for a few hours
split the final mpeg and you ahve a vcd -
Actually, murf would need the VCD template, not the SVCD template. The post indicates the need to convert to VCD...
Impossible to see the future is. The Dark Side clouds everything... -
Originally Posted by harpn
my bad your right use the vcd template
as for the 3:2 pulldown it is the ONLY way to increase to 29.x framrate and personally it looks better .. who wants a slow refreshing PAL anyhow??? -
If it's PAL, then it is going to look crap encoding to 29.97, with or without pulldown. I have yet to come across a 23.976 SVCD, although they may exist. If you really wanted to do this because you thought PAL was someway inferior to NTSC, or more reasonably because you could not play PAL, then the way to go would be to convert properly to NTSC(film) and then use 3:2 pulldown.
What you suggested so far is rubbish. -
Well I appreciate greatly the responces. Thank you much, got it going and I can't even tell the difference between that and a DVD!
Rip VCD to ISO without converting
By cynikalhedonist in forum Authoring (VCD/SVCD)Replies: 9Last Post: 11th Mar 2011, 12:50 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 11:41 -
Burning SVCD to a DVD (Not converting!)
By bebopdeluxe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 09:06
