I have a few questions (please excuse my ignorance if they sound too basic):
1) I have an old Pentium 2, 333 with 4.3GB HD and 64 MB RAM with an old Traxdata CD-burner (CDRW). IDE interface. Any ideas how I can utilise about $400 - $500 to upgrade this as buying a new PC would be outside this price range?
2) Any good DVD-roms that someone can suggest or perhaps tell me where I can find review info. on this.
3) What are the minimum system requirements for converting home movies from both digital handicam tapes and VHS tapes to VCD/SVCD etc. I assume my present PC would fall over, right?
4) Apart from playing/reading DVDs, is there any purpose a DVD-Rom serves. I need this info. before I decide on whether to buy a DVD-rom or stick with my CD-Rom and CD-burner.
Thanks in advance.
Ricky
If you are looking to spend around $400-500 to upgrade a Pentium 2 with a 4 Gig Hard Drive and 64 Mb you can easily buy one of those gateway computers (300SE):
- Pentium 4 Processor 1.8GHz
- 128MB DDR SDRAM
- 40GB
- 40x/12x/48x CDRW
and so...
You can easily upgrage from this basic pacakge later on. This system runs for $599 -
if i were to upgrade this -- i would get as much memory as possable and of course a larger hard drive or two ...
converting a hour of DV to vcd would take you about 12 - 18 hours per hour of raw footage i would guess ..
i dont know were you are but in the usa you can get a something lik a p3 1ghz celron w/ 256 mem and all-in-one mother board and a 40 gig hard drive for 400$ or so ..
i would put the 400-500$ to work that way first .
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 07:54 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 12:13 -
Newbie needs help!!!!!! DVD to xbox 360 streaming
By JohnS719 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2010, 07:38 -
Newbie using DVDfab
By Regor21 in forum DVD RippingReplies: 7Last Post: 10th Nov 2009, 23:04 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43
