I captured a 2 hour home VHS movie using the Huffyuv codec at 640x480 and my capture file is at 56GB, my hard drive is 120GB but it's not enough because when I try to run filters on the file in VirtualDub it's creating a new file that is filtered but can't finish because it runs out of disk space. Two 56GB files just do not make it. Any ideas besides cutting down to 352x480, which I tried but got a lot of dropped frames and the picture has comb like lines on the edges of a lot of stuff in the picture.
Yea, I'm thinking about trying the PicVideo codec, but I like the Huffyuv.
I liked Huffyuv too. Until I discovered the DivX. Used them, and never looked back.
Hello. -
Assuming you eventually want to feed the processed file to another application, you'll find VirtualDub's 'frameserver' mode invaluable. It basically pipes the processed data via a 'pointer' file, without creating an full 'intermediate' file.
I think there used to be a good guide regarding how to set the frameserver within vcdhelp.com's domain, btu I can't locate it at the moment. However, this guide from VirtualDub's official site would probably do just as well.
-- Piggie
best DVD recorder filter & ATI AIW filter
By VCRcomp in forum RestorationReplies: 1Last Post: 27th Jan 2011, 17:27 -
left wondering ... which capture device ?
By hydra3333 in forum Capturing and VCRReplies: 4Last Post: 2nd Dec 2009, 02:23 -
Room for improvement in my capture setup? (VHS)
By Killer3737 in forum Capturing and VCRReplies: 2Last Post: 4th Oct 2009, 15:55 -
VirtualDub Filter During Capture?
By CosmicOutburst in forum Newbie / General discussionsReplies: 4Last Post: 26th Nov 2007, 18:48 -
Converting a Mono Left Channel to Double Mono Left/ Right Channel on a DVD
By socool135 in forum AudioReplies: 5Last Post: 16th Sep 2007, 00:45
. And you may want to use this chart as a comparison.
