i have a samsung sd-612 dvd-rom, everytime i insert a dvd in it, it cant read it always, i have 2 questions:
how do i disable autoply/autorun for the dvd-rom in windows 2000?
what do u think is causing the problem where the dvd-rom cant read the dvd?
thnx![]()
Well, in answer to your first question, I use TweakUI for this. You can get this from Microsoft's site here:
http://www.microsoft.com/ntworkstation/downloads/PowerToys/Networking/NTTweakUI.asp
This utility will give you the ability to select which drives you want autorun enabled with as well as alot of other tweaks that SHOULD have come with Windows.
As to what is causing you DVD-ROM not to read DVDs, I really don't know for sure, but I can give you a few common practice things to try.
How old is the drive? If it is more than a year old and especially if you smoke heavily around your computer I would suggest cleaning the drive with a cleaning disc.
Have you tried uninstalling and reinstalling every piece of software as well as drivers for system devices involved in the playing of DVDs such as your playing software, your motherboard chipset drivers, etc.?
If all else fails, and I mean ALL else, just take the drive out of your computer and give it a few whacks with the palm of your hand. I still can't believe how often this works
Sorry I can't be more specific about the nature of your problem, hope I've been helpful
Prospero
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 09:33 -
Another DVD Rom issue
By dafoe in forum DVD & Blu-ray WritersReplies: 5Last Post: 16th Jul 2010, 12:49 -
DVD-ROM Backup
By 329329 in forum Authoring (DVD)Replies: 2Last Post: 11th Mar 2010, 13:24 -
dvd rom problem
By ieh4f in forum DVD & Blu-ray WritersReplies: 2Last Post: 13th Jun 2008, 03:49 -
hd-dvd rom drive
By computerchuck in forum Software PlayingReplies: 6Last Post: 8th May 2007, 08:55
