I have burned a vcd at 32x and nero said that it burned fine. But when I play it on my standalone dvd player it gives me a disc error. It plays on the computer fine. I try it at 16x, with no luck.
I burn the same vcd on the same cdr brand, at 8x and that plays fine on my standalone dvd player.
Am I doing something wrong?
I have/use:
toshiba sd2200 dvd player
cursor 16x cdrs
mitsumi 480ate 32x12x40x burner
nero 5.5
Results 1 to 9 of 9
just as a note. i burn everything at 48x. i have a memorex cdrw. i use maxwell cdrs. i have a phillips dvd 724. i use nero 5.5.8.2
It is possible that your particular DVD standalone wants a "cleaner" burn.
Supposedly (though I've not come across this personally), a slower burn speed will produce deeper "pits" that can be seen better by the laser on troubled machines.
The 32x burn is not only too fast for your 16x-rated media (you will likely get errors even on a normal data CD), but could be producing worse problems for the standalone because MODE-2 doesn't have error correction - the flaws in the "pits" will be seen more.
I have (had, it just died) an HP 8x burner, and I was able to burn all my movies at 8x without flaws (until the drive died, of course). I hear 32x - 40x burners have 8x as the SLOWEST speed, so I'd use that for all VCD/SVCD burns. It seems to work for you, so...
Some people here claim to even do 1x, 2x burns - I find that a little too slow, unless you absoluely HAVE to. -
I have a Toshiba SD210E DVD player, and burn all my stuff at 16x and have not had a problem with anything yet, be it Music, mp3 or VCD/SVCD and thats an older model, it could be your CDR's try buying a few expensive big brand discs, and try it, it might also might be a problem with the DVD Player, try burning a normal audio CD at the slowest speed you can, and see if it works.
Thank you homerpez and Martyn1980.
I will try an expensive brand cdr, if that doesn't work I'll stick to cheap cursors and burn at 8x.
Martyn1980, what brand do you use? -
It varies i usually use a cheap supermarket disc, cause its only 2 minutes walk from me and im lazy, they are Imation discs and are £10 for 30 and ive had no problems with them, i also use Maxell, Verbatim and Tevion, and an unbranded, which were £18 for 100, but that involved a 15 minute drive
I sometimes use Phillips,Kodak or Traxdata discs, if i get problems with a fussy player or im doing a music CD backup.
does anyone know of a guide that states which brands of cdrs burn at what speeds?
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 14:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
SoNy Handycam CCD-TR411E 32X
By JORDANCK57 in forum Newbie / General discussionsReplies: 38Last Post: 29th Jan 2008, 10:12 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
