Hello
What i want is rip a perfect image of my dvds onto my hard disks, which program would you recommend?
And if i want to rip my dvd and get rid the extra stuff "fbi log, etc" which is the best program to use?
thanks
1-dvddecrypter
http://www.dvddecrypter.com/
2-ifoedit
http://mpucoder.kewlhair.com/Derrow/rcopy.html -
Smartripper is getting a little old.it has not been updated in a long time and it does not deal well with some newer DVD's. But it has many features like it's backup mode which allows you to rip the entire DVD's file structure to your HD and if it's a single-layer disk you burn it directly to DVD-R. It also allows you to re-rip files you already have on your HD.
I also find smartripper to be a little faster then Decrypter, other then that everything wulf109 says is pretty much right on the nose.
thanks for the replies.
So smartripper is old, but has many useful features. Can someone please tell me more about dvd decriptor.
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 19:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 21:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 15:26
