  1. I am using DVD2SVCD and use TMPGEnc but want to try the CCE to see what all the hub bub is about?
    I downloaded the CCE 2.5 SP demo but it does not install? It just opens? When I try to point to the folder its in for dvd2svcd it says its NOT installed???
    How do you install it? Sorry if this seems like a totally moronic question, but I looked here for a how to and found nothing or missed it? I did a search as well but nothing for how to run it or install it??
    I downloaded the manual for it and it says nothing on how to install it???
    Thanks for the info if you can give me any??
    Spankey
    Jul 2002
    BATON ROUGE, LA - U.S.A.
    point to the executable not the folder
    Apr 2002
    Originally Posted by spankey
    but want to try the CCE to see what all the hub bub is about?Spankey
    CCE links
