hi all
now im quite a newbie at this so please forgive my ignorance
ive captured my video using pinnacle pctv rave, converted to mpeg 1 & 2 using TMPGenc & ive burnt my clips using nero 5.0 vcd wizard & when i put cd into dvd player it says play but i get no pictures or sound on tv
clips are mpeg 1 or mpeg 2
(if i copy a vcd i dont have a problem its only with captured stuf)
dvd player is a dansai 1010 with vcd upgrade installed
can anyone help?
thanks for your time & answers
Have you used the standard templates from TMPEG for VCD SVCD ?
If not maybe your player isnt able to play VCD doesn´t confirming to the standards.
Or the bitrate is too high.
Therefore you said you got an VCD upgrade for your player.
SVCD is MPEG 2 so maybe unsupport by your upgrade chip.
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
A hardware prob, but what?
By ahhaa in forum ComputerReplies: 3Last Post: 22nd Sep 2009, 21:00 -
Wireless prob?
By Immortal25 in forum ComputerReplies: 4Last Post: 3rd Jun 2009, 07:55 -
gc prob
By Mr anderson in forum ComputerReplies: 6Last Post: 10th Sep 2007, 05:33 -
MPEG DV prob
By mainegate in forum ffmpegX general discussionReplies: 0Last Post: 24th Aug 2007, 17:01
