i was wondering if anyone knows a good technique to help improve the sound on movies that you download off kazaa. Some of the ones i have are screeners and the volume is way to loud and it makes peoples voices sound all funny cause it's up too loud. also some of them have a hissing noise in them...what program can i use to fix this and what are the best settings for that program.
I know you experts can help me out on this one!![]()
Try Gold Wave. Load the original video into it. If it is too loud, go to Effects-->Volume and lower it until it is at an acceptable range. If it has a hiss, load it and go to Effects-->Filter-->Noise reduction. Hope this helps.
Hello.
Fixing sound sync issues in a mkv file
By Psykro in forum EditingReplies: 12Last Post: 20th Dec 2014, 11:31 -
VirtualDub - Editing and Fixing Sound
By bpatters69 in forum EditingReplies: 1Last Post: 26th Oct 2009, 12:33 -
TV that needs fixing....
By SE14man in forum Newbie / General discussionsReplies: 5Last Post: 3rd Nov 2008, 16:00 -
Fixing some videos
By Broka in forum RestorationReplies: 22Last Post: 21st Dec 2007, 21:14 -
Fixing muffled sound on .avi file
By kman0199 in forum AudioReplies: 1Last Post: 7th Jun 2007, 00:40
