Ok Erm, This Might sound dum to a lot of you but this is the only place i could think of to ask for help.
I am new to the video editing game and i made an intro for my movies in swish, a flash copy.
I saved it as an *.avi file and i wanted to merge it with my final avi movie, the problem is, it says the two files have different sampling rates in virtualdub, therefor it wont append the video segment.
I have tried re compressing the swish exported avi to the same compression and frame rate etc as my final avi film but i still get something to the extent of "the two files have different sampling rates".
I know this can be done, I once downloaded Dog Soldiers from tmd-moviez which had a flash movie as an intro, which was part of the film itself.
This is really stressing me out, if anyone can help this would be gratefully appreciated.
AVI joiners insist on the two clips being configured precisely the same, the only way to ensure this is if the clips where created by the same product.
You could try 'EO Video' to join them (see the tools section) although I suspect you will have the same problem with this.
I think the only way to join two dissimilar AVIs is to use a video editor such as 'Ulead Video Studio' or 'MovieXone' which accept clips of different specs and renders them as a new combined clip. -
I've got the same problem with a divX movie. There are missing the credits at the beginning, so I've downloaded an other file. Now I can't put them together (well, I could use Media Studio, but then I'd loose quality).
There are so many programs for ripping DVDs and converting AVI's to mpgs. There must exist one for merging two avi files...
Merging files
By drtbray in forum EditingReplies: 12Last Post: 13th Apr 2012, 16:08 -
Merging avi files with subtitle and aac soundtrack
By kurian in forum Video ConversionReplies: 5Last Post: 31st Jan 2011, 02:52 -
Problem in merging splitted AVI files of a movie into one.
By nick2712 in forum Newbie / General discussionsReplies: 8Last Post: 2nd Oct 2010, 14:20 -
Quality problems after merging two .avi files
By Metallo in forum EditingReplies: 14Last Post: 13th Aug 2008, 09:50 -
Problems with merging to avi files
By mingul in forum Video ConversionReplies: 3Last Post: 6th May 2007, 10:06
