hey board...i was wondering if anyone knew whether or not a panasonic cv37 could play vcd's...it does have cd-r, cd-rw playback...so i thought it might...if anyone can help me i would really appreciate it...
I would love to know where did you get that analogy, as my VHS player can accept S-VHS cassettes as well, and I was wondering if I can use the same analogy to make it play Beta SP tapes, too. After all, both are tapes.Originally Posted by El Torro
Sacmonkey - the easiest, and safest way to check, if it isn't stated on the manual/front, is to make one and check. You say it reads CD-RW? Make a VCD on CD-RW and check. The Player is still in the store? Bring the CD-RW to the store and ask them to pop it in.
-- Piggie -
El Torro, there are plenty of DVD players on the market
that advertise cdr(rw) but cannot play VCD. Some won't
play SVCD.
so unless u know for sure..... el silencio por favor!
