  1. I have a ALL IN WONDE 32DDR card and it dosent play or record in stereo ,I belive it is the motherboard it is a ABIT KT7-raid (great board) has a VIA chipset in it, Also had a problen with a Logitech webcam not working properly that was also traced back to the chipset ,currently downloading, updating, flashing bios, ect ect to see if anything will work .Does anybody have a fix ? ....that can narrow it down on what I am supposed to do .Running XP and ME, problem is the same on both OS's Thanks
  2. Hey Morbius,
    are you sure it doesn't play in stereo? I used to have the problem that MMC would SAY it was mono when in fact it was in stereo but I think it was always in stereo when I captured. But my next question is do you have the newest drivers and the newest MMC? That fixed my problem instantly. Give that a shot.
    Macros
  3. There is sound only coming out of one speaker also when i burn a vcd the same thing sound only out of one speaker By MMC do you mean ATI's latet software and drivers ?? if so yes loaded the latest version last week and still the same .. This morning put in video card in a spare PC and got Stereo out of it so it must be that via (CRAP) chipset . at this point solution is getting a non VIA (CRAP) chipset ..any suggestion have a 1400MHZ thunderbird processor, and plannig to build a new system is over a year away PS would like to keep RAID feature
  4. I have a VIA chipset as well. Do you have the newest 4 in 1 drivers? That can sometimes help. If that doesn't work I'd try this.....it sounds ridiculous but it works. EVERY single problem I've ever had with ATI has been solved by completely uninstalling everything ATI and then reinstalling. So after you try the 4 in 1 thing....(have you updated soundcard drivers by the way?....what sound port do you have your AIW plugged into) and after you try updating sound card drivers do this: Uninstall all your ATI drivers, delete all ati files using find file (be sensible here...only delete files you are SURE are ATI files) then clean out your registry of ALL ATI entries using reg cleaner (or similar). Then reinstall the newest drivers, the newest capture drivers, the vfw wrapper and then MMC 7.7 in that order. I'd be surprised if that didn't fix your problem.
    Macros
    p.s. I KNOW it is a pain in the ass.....but I can't tell you how often it has worked for me
  5. YUP loaded the latest 4 in 1 drivers this morning and did pretty much all of the above .the last thing I can thing of is that my harddrive is on the raid IDE controller part ,its proably that its always the last thing you try before givingup if that aint it i will be at the latest PC show buying a non VIA (CRAP) chipset board ..thanks
