Whats the difference between ntsc 16.9 525 lines,pal 16.9 625 lines and 16.9 under video source setting in tmpgenc.
If i have a widescreen movie to encode to vcd and its pal 16.9 would i b better off setting the video source to pal 16.9 625 lines or just 16.9 ,as under video stream settings where u choose what u want the mpeg to b there is only a 16.9 525 lines and a 16.9 625 lines.
Also does any one know what 2.11:1 and 1:1vga is ?
Also if i have a divx to convert to vcd 16.9,should i change the source setting from 1:1vga to 16.9 525 lines for ntsc and 625 lines for pal.As if i leave it on vga the ratio dont seem right once converted to vcd.
Thanks.....
Results 1 to 1 of 1
iMovie and aspect ratios
By sphinx99 in forum MacReplies: 3Last Post: 10th Mar 2010, 23:18 -
multiple aspect ratios on one DVD?
By towtruck in forum Authoring (DVD)Replies: 11Last Post: 7th Jul 2008, 02:58 -
Having problems understaing aspect ratios
By PlayWithFire in forum Newbie / General discussionsReplies: 2Last Post: 16th Nov 2007, 09:40 -
Aspect Ratios
By gayclarke in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2007, 15:13 -
Aspect Ratios / Dimentions / HD Problems
By Aviewanew in forum EditingReplies: 8Last Post: 21st May 2007, 22:23
