Hey there!
Im newbie ih this VCD thing! So I'll bother you guys a little!
I was trying to capture VHS tapes and then converting it to VCD's. I got it, but the results was not so good as I thought. I mean, my xvcd runs in my standalone dvd player (pionner dv-353), but with glitches, image got frozen for a moment (1 sec at each 3 mins, for example). I can watch it fine but itīs not so smoothy...
Is it normal? Do your captured movies plays just fine with no stops in your DVD players?
XVCD's that I made using as source DVD or even DIVX are almost perfect. No stops, no glitches...
I usually capture at 352x480 with picvideo MJPEG codec and audio PCM. Then I use KVCD templates with TMPGenc 2.58. I remux with bbmeg as MPEG-1 file and with default options.
Can dropped frames produce that? With that config I have almost no dropped frames (10~20 dropped frames by 100 mins of capture)
Am I doing something wrong? How to eliminate that evil freezing!?
Thank you for any help given!![]()
I'm working on basic VCD capture "How To". You should find some answers there...
http://steve.kittelsen.com/vcd/ -
Hello skittelsen!
Tanks for your advice!
I've read your article. Very interesting!
But concerning the resolution, I guess I canīt capture above 480x480 (under win xp, never triend in win 98). My phoebe tv master +fm allows me change the resolution but I got a high number of dropped frames (at 29.97 fps). And also I dont have a powerfull processor, itīs a cel366@550. So I do it at 352x480. I'll try later under win 98 (with another drivers) and see if it works.
Another interesting thing is that if I use default TMPG templates (with no demux and then remuxing with bbmpeg) the movie stops for about 30 secs (at each 2 mins) in my TV.
I use to burn with VCDEasy or Nero.
Well, I also tried:
Increase bitrate
Increase VBV Size
Encode as Standard VCD or (X)VCD
but nothing worked!
For that I asked if its normal that freezing! I guess I'm in the right way! Or not?
Cheers!
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
What's new in capture cards for VHS capture?
By chowmein in forum Capturing and VCRReplies: 21Last Post: 29th Jul 2010, 08:03 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 22:16 -
VHS to DV capture: Component video vs. S-VHS
By vega12 in forum Capturing and VCRReplies: 8Last Post: 19th Feb 2009, 19:42 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31
