Is it possible to burn a vcd onto dvd media? Thereby allowing you to put 3 complete movies (6 - 680 meg dat files) onto a 4.7 gig disc.
I believe 4.7GB is really 4.2-4.3 because of that whole MB or 1000000bytes thing. That's still over 7 hrs per disk.
I believe you will still have to re-encode the audio, but it should be possible. -
Let me clarify. I know the new Daewoo DVD player 4000 series lets you play mpg files off of a any disc individually. But I was wondering if you have a DVD burner on your computer and run Nero and select VCD. That if you have a DVD-r in the drive does nero let you utilize the 4.3 gigs of space for the VCD you are making. Is this possible?
Thanks Again -
BTO,
interesting question. You should be able to burn in udf 1.5 and
have access to mpeg-1 in such a DVD player - in theory. I have
a feeling you would not be able to view the files/folders but be
able to press next to run through them one by one - rather
like a dvd disc with PBC off. -
You can certainly use VCD compliant mpeg-1 files when authoring DVD-video (audio re-sampled at 48khz) and so get loads of stuff on a DVD-r. As to whether the Daewoo player mentioned will play mpeg-1 files written as data to a DVd-r, I would say the best way to find out would be to try it!
Thanks for your help everyone, especially Bugster. The Daewoo DVG-4000S reads files off a CD-R or CD-RW and puts the appropriate icons next to the file name ie. MP3 or VCD, or ? next to unknow file formats. This I have tested. I will know tomorrow if the data DVD-R is also file browsable and will post the results here. By the way, the Daewoo is a good choice for a bedroom DVD player as it is only $89.00 and plays every type of format and also has folder & file browsing.
Thanks again,
BTO
Making a snapshot on Windows Media Player
By bryankendall in forum Newbie / General discussionsReplies: 4Last Post: 25th Jul 2011, 11:35 -
Making a VCD to send to the Philippines
By StrikerZERO in forum Authoring (VCD/SVCD)Replies: 17Last Post: 7th Dec 2010, 10:11 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 13:03 -
Making VCD Copy
By audiophile in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th Sep 2007, 08:20 -
General Guidance and Hardware req. for making VCD with Digital Camera
By dpilot83 in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2007, 06:53
