Hi,
I have been totrally unable to create a VCD of any type that will play in my standalone player without slipping audio sync (plays fine in PC and will come back into sync after pressing pause).
I have a PAL VCD (original) of Back to the Future that I bought - this plays with absolutely no problem. Is there any software out there that will allow me to analyse the working VCD and learn the GOP structure, bitrate etc etc. I will then attempt to create my own VCDs with the same structure.
Many thanks,
Gareth
if you use the TMPGEnc VCD template - you will have exactly the right structure ..
audio sync issue is not releated to GOP format (unless you mucked w/ the standard vcd setting) .. -
Hi,
I have tried the tmpenc template. I still have an audio sync issue. My VCDs are absolutely fine in a PC and they come back into sync if I press pause on my standalon player (aiwa). If I watch a movie from beginning to end - by 1 hour in, the audio is about 1/2 second out.
I have tried everything.... Someone before suggested that the GOP may be to blame.
Thanks,
Gareth -
This happen on my friend DVD player too.
It's just the DVD player, it will play originals fine, but anything on a CD-R is hates.
Best you go buy a new one, and test it out in the shop, i had to test 2 DVD players before i fond one that actually play everthing i wanted it to.
and don't just think it will work cos that it says it will play a vcd on the box, cos that ain't true.
RobDVD to VCD made eazy
http://www.eazyvcd.tk
incorrect GOP when trying to author DVD with files extracted from VCD
By ibzomie in forum Video ConversionReplies: 2Last Post: 20th Jan 2012, 09:58 -
I need help with open gop i think
By Rathgar in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2012, 15:29 -
Analysing loudness of video files
By scorpiousdelectus in forum Video ConversionReplies: 13Last Post: 30th May 2011, 09:32 -
Questions about GOP.
By Sean_ve99 in forum Newbie / General discussionsReplies: 11Last Post: 8th Jun 2007, 23:08 -
VCD to DVD (TDA error: GOP too long)
By jelir in forum Authoring (DVD)Replies: 1Last Post: 6th Jun 2007, 09:40
