Help. I am new to video converting and have hit a wall. I have numerous old VHS tapes that I want to convert to VCD. I have tried several different capture tools (some freeware and some commercial) and all have the same problem. Thus, I am thinking it is a keyboard interface problem. I can capture (either to AVI or MP2) quite fine. However, when I try to play the capture back the video pauses (with a continuous frame repeat) after about 10 seconds even though the audio continues on just fine. I have tried capture from my VHS-C and it does just perfectly. No problems at all. The problems occur when I try to capture from my VHS player. I have been using (mainly from a flexibility persective) VirtualDub and Tempgenc with all sorts of various settings. Some I got from these forums some from just playing. Can anyone help me decipher my way through this mess.
Thanks,
Ed Smith
Do you have an ATI card?
You might be seeing macrovision protection kick in. -
Originally Posted by snowmoon
On a side bar, I am considering getting the Happauge (sp) TV capture card. Any comments on this choice?
Thanks,
Ed -
Not ever format can carry the macrovision signal. ATI cards often misinterpret poor signal quality with macrovision.
I moved from an ATI card to a WinTV-FM PCI card because of driver hedaches. -
snowmoon,
Thanks. I think that is about the convincing that I needed. I wonder why when I even use their (ATI) MultiMedia center program it does not seem to have anyproblems recording but does have the described problem even with its own recordings.
Ed
VCR buying guide (S-VHS / D-VHS / Professional)
By lordsmurf in forum RestorationReplies: 322Last Post: 18th Mar 2025, 14:04 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 14:25 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 08:19
