    Indonesia
    i want to ask how to cutting from 1 files mpg to separate files mpg
    example i want to cut 10 second from beginning, 20 second in middle and 10 second from last. but when i generate it it will give me three files not one files.
    Australia
    If I read this right you want to end up with 3 separate files.
    Use 'TMPGenc' (available in the tools section of this site).
    1. Select 'File' -> 'MPEG Tools'
    2. Select the 'Merge & Cut' tab.
    3. Select the 'Type' that matches your MPG file.
    4. Use the 'Add' button to add your movie to the file list.
    5. Double clik on the name and set the start and end range for the first cut.
    6. Enter a new name and Save this cut.
    7. Edit the file again and set a new start & finish time and save the new cut as a diferent file.
    8. Repeat this for the final cut.
