Hi guys
I have been reading through the guides for reducing movie files bigger than 4.3GB to enable them to fit on 1 DVD blank, but I am stuck now whichever method I follow because you can't get DVD Maestro anymore.
I am able to go all the way through the digitalforums' dvd2dvdr method (for example) right though to having an ac3 file and a m2v file, but can't get any further withough DVD Maestro.
Is there some other way of compiling these two files to created the usual VIDEO_TS folder?
Help!
Roy
Combat Model : Optimum Self Sufficiency
"..we're not computers, Sebastian - we're physical.." -
Dude, I used the same guide you used. Just substitute SpruceUp for DVDMaestro, and you are good to go.
-J
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 22:11 -
DVD Maestro Entry Point Not Found Error
By criver in forum Authoring (DVD)Replies: 7Last Post: 9th Aug 2011, 12:42 -
DVD Maestro - Multiple assets, one VTS
By alfini in forum Authoring (DVD)Replies: 0Last Post: 10th Nov 2010, 02:32 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 04:22 -
Help! DVD Maestro RealTime preview. Cinemaster not working.
By IJM in forum Authoring (DVD)Replies: 10Last Post: 1st Jan 2009, 04:22
