  1. Hey,
    ok, i got my dvd-r today... I burned a small 1 minute clip onto a dvd-rw...
    The menus are cut off on the top, bottom and sides on the tv screen, there are no black lines how ever, it is full screen, just cut off... I tried changing the settings on the dvd player, but that didnt help...
    Also, the clip that is on the dvd-rw, the audio pauses for a few seconds, every few seconds...
    I am playing the disc on a pinoeer dv-343 and am using a Verbatim DVD-RW, i am authoring with Spruce Up...
    The disc works fine in my dvd player on the computer, just not the tv... Could it be that my player doesnt like dvd-rw, but then why would the menu do that? Thats just weird... The DVD Player compatibility list says it works with DVD-RW, thats why i bought it.... Any help would be greatly appreciated!
    Matthew
  2. Hey,
    me again... The clips is DVD compliant, and spruce up accepted it...
    Matthew
  3. What is your bit rate ? (too high video bit rate is known to cause this problem)
    Why don't you try MyDVD! (which comes with the DVD-R) It works fine for me.
    Thank you.
  4. my bitrate is 4000 which should be ok
    Matthew
  5. Hey,
    Ok, i fixed the audio problem... I am now using DVDit... The menu problem is still there... I am going to try to use a driffrent resolution picture, right now I am using the highes 1024 something, so, i figure the dvd player may say its to big and crop it...
    Matthew
    Jul 2001
    Maryland
    dvd resolution is
    740x540 i think
    a height of 1,000 is way way to big.
