System specs
900mhz AMD TB
348 megs of ram
WIN XP
5400rpm 40gig HDD
When i try and capture in mpeg 1 it loses 50 percent of frames. I cannot capture over 320x240 in VDUB or I lose frames. I was under the impression that this card could capture at high resolutions higher than that without frame loss on a 700mhz pc - and mine is 900mhz
Also the 320x240 capture at 6000bits/sec dont look as good as the ones I did on my WINTV GO card
any suggestions?
Results 1 to 1 of 1
Ok - you got me - i dont know anything - you happy now!
ATI PCI Theatre 550/650 vs AGP AIW 7500, 9600XT
By TaranScorp in forum Capturing and VCRReplies: 3Last Post: 6th Sep 2009, 14:45 -
ATI AIW 7500 64M Replacement?
By TaranScorp in forum Capturing and VCRReplies: 20Last Post: 6th Aug 2009, 11:56 -
ATI AIW 7500 TV tuner washes out every 6 seconds, then back to normal
By Keitho in forum DVB / IPTVReplies: 0Last Post: 15th Jan 2009, 13:01 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 05:11 -
ATI 7500 All in One Wonder
By justmehere in forum Capturing and VCRReplies: 3Last Post: 8th Feb 2008, 15:08
