Hi just bought myself an APEX 1100W, and it's the newer models with a 08 at the end. I'm not sure if there is a hack for it, but anyways, as I found out it no longer supports VCD, but that's beside the point. I'm now starting to convert my DIVX films to SVCD (because my player doesn't support VCD as mentioned) and was wondering if there was a way to determine the output size to ensure that it will properly fit the cdrs. I was playing with the TMPGEnc tool, but I couldn't find any option that will allow me to determine this. I would just like to know if there is a way so that I don't need to eyeball it and hope that an hour later it'll fit. Many thanks to those who can help me with this. One last question, in the instructions that was provided from here, it seems that after I do each cd, I have to restart the sequence for the following cd. Is there also a way to get this automated sequencially? Many thanks...
Results 1 to 1 of 1
how to determine aspect ratio of clip for DVD output?
By perfection in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2011, 02:02 -
Output size in AVStoDVD
By VenusAndMars in forum Authoring (DVD)Replies: 2Last Post: 25th Nov 2010, 18:07 -
How to determine proper video size and aspect ratio?
By Bonie81 in forum Video ConversionReplies: 13Last Post: 25th Apr 2010, 03:57 -
Is there an easy way to determine the frame size of videos?(avi, mpg, etc)
By True Colors in forum Newbie / General discussionsReplies: 2Last Post: 17th Apr 2010, 16:45 -
how to determine file size in megui
By scorpio1959 in forum Blu-ray RippingReplies: 2Last Post: 30th May 2008, 09:39
