I have a PCMCIA Card Bus 2 port firewire card for my laptop. Its DV input works great with both a camcorder and DVD recorder. However, I cannot get it to send DV back out to either. The DVD recorder simply says no DV input found, while the camera shows a blinking video signal for about 5 seconds then nothing. I've tried both DVIO and Ulead VideoStudio 6 software with the same results. I think it may be the card (a cheap Koutech model) but am not familiar enough with 1394 to really know. Anyone got ideas or thoughts?
Be sure you have your Control Device set for your DV card. I know you have to do this in Premiere before it will export anything.
Is there any DVD Player with FireWire output? (no recorder)
By Sean_ve99 in forum DVD & Blu-ray PlayersReplies: 24Last Post: 4th Jun 2009, 13:58 -
I need high def 1920x1080 with firewire output
By jahmer in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 24th Oct 2008, 06:30 -
JVC SR-VD400US output via firewire to the PC?
By nathan118 in forum RestorationReplies: 2Last Post: 3rd Jan 2008, 11:23 -
Firewire Output on Pioneer DVR-510H
By BroadcastTech in forum DVD & Blu-ray RecordersReplies: 4Last Post: 24th Sep 2007, 02:53 -
Recording Firewire output from Vegas timeline
By Richkut in forum EditingReplies: 3Last Post: 10th Aug 2007, 07:36
