I am not able to open any file captured from my DV camcorder. I have tried capturing using Studio 8 and also with Ulead Videostudio 6. Vdub complains:
"Couldn't locate decompressor for format 'dvsd' (unknown)"
then goes on to explain that it cannot open files created with directshow based codecs, only VFW.
So, is there any VFW codec available to handle these files? Vdub never recognizes my IEEE 1394 port, so I can't capture with it, but is there another way to capture from my camcorder that will be compatible with Vdub?
If you have WinXP then you don't have Video For Windows support by default. I solved the same problem by using the codec from an old copy of Studio DV. Other's said they had success with the Panasonic codec. Search the forums for dvsd or Panasonic for the link.
VirtualDub Error 'Says "Couldnt locate decompressor for format xvid"
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jul 2010, 00:05 -
VirtualDub..cant set custom format or compression???
By jranaudo in forum Capturing and VCRReplies: 4Last Post: 16th Jan 2010, 11:54 -
virtualdub problem: source image format is not acceptable
By jorwex in forum Video ConversionReplies: 12Last Post: 2nd Sep 2009, 06:01 -
Can VirtualDub record VHS tapes to AVI format?
By gregnovella in forum Capturing and VCRReplies: 4Last Post: 29th Apr 2009, 00:37 -
join 2 AVIs w/ VirtualDub, Truncated or invalid decompressed audio format
By Madgelina in forum EditingReplies: 3Last Post: 6th Mar 2008, 14:25
