Can I capture DV with firewire with any of this software?
If not what is the best for Capturing DV?
Personally, I like DVio http://www.carr-engineering.com/dvio.htm. I also like DVD movie factory, and Edit studio 3 http://www.puremotion.com, though the last one can be a bit buggy (esp. editing).
With DVio I can capture from my Razzle DV bridge to a firewire connected hard drive (Seagate 80GB in a Chump USA enclosure) through my old laptop (Toshiba Portege 3010CT) with a mobile pentium 266 (not even pII tech.). I use a cheap Chump USA brand pcmcia card in either slot. The drive has 2 firewire ports, one goes to the DV bridge, the other goes to the computer. This arrangement seems to use the least amount of computer resources.
Hope this helps, good luck.Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Firewire device to computer with no Firewire
By dbuser2 in forum ComputerReplies: 11Last Post: 24th Sep 2010, 21:32 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 14:26 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 12:19 -
Firewire Help
By Metalchris in forum Newbie / General discussionsReplies: 1Last Post: 15th Jun 2008, 23:12 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08
