i have been converting the bitrate of m2v files that are too large for a dvd-r so i can re-author them to fit. all of a sudden dvdsp won't see the m2v files. i can't figure out what i did. anybody ran into this before?
What do you mean by "won't see"? Are you talking about not being able to select the file when trying to import? If so, click and drag the file to the asset window. If there is some kind of problem with the file, DVDSP will display a error message. If it says "Bad Format" run the file through MPEGAppend.
MPEGAppend for OSX trial:
http://homepage.mac.com/DVD_SP_Helper/Commerical/MAOSuX.html
MPEGAppend for OS9: http://homepage.mac.com/DVD_SP_Helper/Download/Download.html
DVDSP output multiple copies?
By MikieV in forum MacReplies: 10Last Post: 8th Dec 2010, 12:10 -
Livetype tot DVDSP help
By whiff79 in forum MacReplies: 3Last Post: 14th Mar 2010, 10:23 -
TRUEHD reencoded to AC3 vs Embedded AC3
By chenjm in forum Blu-ray RippingReplies: 1Last Post: 2nd Feb 2009, 15:48 -
DVDSP Authored DVD - Cleaning the Code for replication?
By Adam Bolt in forum MacReplies: 2Last Post: 20th Jun 2007, 03:45 -
Motion&DVDSP-Square/Rectangular Pixels
By stretchweider in forum MacReplies: 4Last Post: 5th May 2007, 18:41
