I've burned a VCd, and tryed to play it on my Emerson DVD/VHS player. Everytime I try, it says
Disc Error: Playback feature may not be available on this disk.
I don't know what to do. I burned the CD-R with Nero. Can anyone help me with my problem?
Try with cd-rw or another cd-r brand.
Exactly how did make the VCD?
And please try to choose a better subject next time, that describes your post instead of just heeeeelp. -
Well first I got the spiderman VCD from a friend. Then I took the first cd, and copyed it to my computer. Then I chenged the movie from DAT format to MPEG format. Then I went to Nero, and I choose the VCD option. I put the MPEG movie into the MPEGAV folder (where the DAT form was), I made a menu. hen I burned it to a CD-R. I put it into the DVD player, and it said loading for a minute then that screen appeared.
You've missed the point.
Your player more than likely wasn't designed to play CD-R/W discs and simply can't read the VCD you just burned.
Try experimenting with other brands of CD-R or CD-RW media. CD-RW discs often work better in these cases.
Regards.Michael Tam
w: Morsels of Evidence
