Hi,
Has anyone managed to get DVD+Rs to work with the Sony DAV-S500? I'm trying to buy a DVD burner but not sure which type to go for. I think the S500 plays DVD-Rs but dont know about +Rs. Is there any benefit in getting +Rs rather than -RS ???
Thanks for your help.
Andrew![]()
I would advise DVD-R as it seems to work with most sony DVD players, as for DVD+R, If you buy a DVD+R writer make sure that the Drive you intend to play the disks in excepts DVD+R, if you are not sure go for the safe bet DVD-R. If possible ask around to see if anyone you know has a DVD+R writer to make a disk for you, if not go to a company who put videos onto DVD and ask them to put a short bit of vhs video onto DVD. Many firms can put the video onto DVD-R or DVD+R, if the video is short,e.g 2-3 min then it will not cost much, e.g. at some places less than $20. Trust my spending $20 so see if DVD+R works is well worth the effort as all DVD writers are expensive at the moment. Sorry I cant be specific towards your player but I have to say from past experience always test something before you buy - you could end up saving a lot of money. I have on old Sony DVP-S535 and it reads DVD-R with out a problem - you can work out if your player is a newer model in which case DVD-R probabley will work too.
I just bought the Sony DAV-S500 and an HP DVD200i burner.
Using the DVD200i means, that I use DVD+R. It works
I have problems playing DVD+RW, it's jerkily, that means approx every 12 seconds it stopps playing. But sometimes there is no problem at all
I was told by Sony-people that it wouldn't work at all, neither -R nor +R. Therefore I decided to buy the HP and to try it out.
Ask the sales people to return the burner if it wouldn't work.
HTH
Urs
Sony BDP-S500 DVD Region Q's
By DJAGE in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th May 2016, 14:20 -
DVD Unlock Codes for Philips DVDR 3506 and Sony DAV-FC9
By DanSF in forum Newbie / General discussionsReplies: 4Last Post: 29th Sep 2009, 03:13 -
looking for region free for sony bdp-s500
By 123groper in forum Blu-ray RippingReplies: 1Last Post: 29th Jul 2009, 10:23 -
Sony DVD dav-fr1
By Gerard Russell in forum Newbie / General discussionsReplies: 1Last Post: 16th Nov 2008, 00:55 -
Need help unlocking Sony DAV-DZ150k dvd player - pls & thanks 4 help!
By Aussie Gal in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Jun 2008, 03:17
