I have a 45min avi dvd rip that was apprently encoded for the krystal codec. Allthough i can play the file none of my encoders/rippers will read the audio (ac3). i did see a post where someone suggested using avisynth to decode the audio, but the only avisynth i've used was for flask mpeg encoder, which won't open avi files.
Anyhelp would be appricated
file info
video:
512 x 288, 24 Bits, 64351 Frames, 23.976 Frames/Sec, 122 KB/Sec, DIVXMPG4 V3
Audio:
Unknown Format
(but the nfo file that came with it said it was ac3)
BTW it is an episode of stargate sg-1 ripped from a dvd
thanks
Bester
Results 1 to 1 of 1
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 21:53 -
Convert AVI with H264 and AC3 to AVI with XVid and AC3
By ashwin.terminator in forum Video ConversionReplies: 4Last Post: 26th Jul 2009, 11:17 -
Audio doesn't play in AVI files, although AC3 codec IS installed
By DVantrease in forum Software PlayingReplies: 2Last Post: 16th Jan 2009, 17:57 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
converting mpeg2/ac3 and avi/ac3 to avi/lambmp3
By corumz in forum Video ConversionReplies: 2Last Post: 17th Sep 2007, 09:32
