Can anybody help!!
I have just installed a WINTV USB and I am trying to get it to record TV programs using the RF aerial. I have had a look at the Help guides I it shows a setting and MPEG in the Capture section of the WINTV2000. I only have Still images. I also have TMPGENC installed.
I am missing anything??
The quality of the picture is not that good, but if I plug the aerial into a tv set the picture is fine. Is ther eany setting I need to look at.
My system is a AMD1800 with 512k memory about 80gig of disk.
Any help would be great.
Results 1 to 1 of 1
Which is better quality capture- DVD recorder or Hauppauge WinTV USB stick?
By akalsha in forum Capturing and VCRReplies: 9Last Post: 6th Mar 2012, 19:57 -
Need Help Capturing with VirtualDub and Hauppauge WinTV via Svideo
By ibAdam in forum Capturing and VCRReplies: 5Last Post: 21st Aug 2011, 22:01 -
Capturing from Hauppage USBLive2 WinTV device !!!
By imperialguy in forum Capturing and VCRReplies: 0Last Post: 23rd Jun 2011, 17:13 -
WinTV HVR 1800/1850 - interlaced capturing?
By justin81 in forum Capturing and VCRReplies: 1Last Post: 10th Jul 2009, 11:13 -
Hauppauge WinTV 2Go capture card was Kworld DVD Maker USB 2.0
By Vampire74 in forum Capturing and VCRReplies: 4Last Post: 19th Jan 2008, 10:59
