This has happened twice now, so I know it isn't a fluke. When I import the chapter list into Maestro from Chapter Xtractor I get an I-frame insertion error about the frame rate not matching (error 0xc102008b). Xtractor was set to 29.97. Maestro says the movie it is 29.97 FPS Drop. Even if I set Xtractor to 24, it doesn't work. The movie was transcoded with ReMPEG and I believe the last movie that had this problem was, too. Why is this happening? And how do I fix it? Thanks.![]()
Scott.
Results 1 to 1 of 1
DVD Maestro Entry Point Not Found Error
By criver in forum Authoring (DVD)Replies: 7Last Post: 9th Aug 2011, 11:42 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 03:22 -
dvd-lab: import chapters
By cL0N31 in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2008, 20:32 -
import error
By mypumpkins in forum Newbie / General discussionsReplies: 2Last Post: 16th May 2008, 07:40 -
Import .chp list from ChapterXtractor to Maestro error
By rbatty11 in forum Authoring (DVD)Replies: 2Last Post: 13th Aug 2007, 12:20
