I'm just getting into putting downloaded movies onto CDs. I have a few that are too long to fit on one CD. Where do I go to cut the time so I can use two CDs, or make it smaller to fit one CD?
Thanks,
J M L
BLUE944
If you try to make the mpeg smaller to fit the disk (XVCD, 1 disk template) it may no longer play on your DVD player. Or even if it did, it may not play on others/new DVD player, they will also have lower quality.
In TMPGEnc select File > Mpeg tools
1, Now click the Merge&cut
2, Select "MPEG 1 Video CD" from the drop down list
3, Click the ADD button to add your move
4, Highlight your movie in the box and click edit
5, Now move the slider to the end to get the playing time
6, Now move to half of the playing time in the middle and click } (Mark end) Click OK
7, Type the name and location into the output box (c:\part1.mpg) and click start
Do the same for part 2 -
Thank you very much for a fast reply. I'll do this today. I'll let you know how well I make out.
John
BLUE PORSCHE 944BLUE944
Edit a movie (avi), cut some scene but KEEP subtitle in synq! HOW TO??
By GiBsom in forum EditingReplies: 5Last Post: 18th Dec 2013, 19:58 -
Cut DVD movie, is update necessary?
By dexter30 in forum Authoring (DVD)Replies: 2Last Post: 2nd Sep 2011, 07:55 -
Need Help with Movie Cut Short
By shalini72 in forum Newbie / General discussionsReplies: 7Last Post: 2nd May 2010, 02:02 -
Final Cut Pro Movie to x264 mp4
By skywriter in forum ffmpegX general discussionReplies: 0Last Post: 8th Feb 2010, 15:19 -
How to Cut out a scene in a movie using convertxtodvd
By tealmarlin in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2009, 08:49
