the topic pretty much says it all. Thanks in advance.
Look at the left panel under How to ....Convert.
There's not much to do but then I can't do much anyway. -
i follow what the guide said, by using vitual dub 1.3 to convert the asf file to wav or mp3, but when i load the asf file in vitual dub give an error of no video stream (which is right cause the asf file only has sound) so i went ahead with the setting on the guide, but at the end it won't let me save the wav file (the selection of saving .wav file was dim so i can't select it)
Did someone say from asf to vcd ......... are you feel real ? why would you do that. Making high quality RIPS ha haha haha ha .
C-Dub you need to stop posting.
Warlock110 you can use EOVideo to convert your ASFs and RMs to uncompressed AVIs then do your converting in Virtual Dub. -
Don't forget that any tools that will convert wmv (video) or wma (audio) will also convert asf. The standard is backwards compatible. The new wmv8 codec produces pretty good stuff. The RM9 codec is leaps above anything else they have ever produced. The only problem with converting from RM it will likely have a variable "Framerate" (yes I said Framerate) the resulting avi output may go in and out of synch.
I too have seen some poor asf and rm that for me were still worth converting just because I wanted to do it. Anyone who has seen good quality files produced with the newer codecs wouln't laugh.There's not much to do but then I can't do much anyway. -
Thank you Faceman101 and all the others for the help i'll try your method out. and C-Dub if you read my question carefully then you would see that i'm trying to get the audio of .asf file to mp3. and rm to mpg, not asf to mpg.
How can I convert ASF file?
By QuattroNN in forum Newbie / General discussionsReplies: 2Last Post: 29th Apr 2011, 13:11 -
How to convert .asf video file
By peter762033 in forum Newbie / General discussionsReplies: 6Last Post: 21st Mar 2010, 10:29 -
Can not convert .asf to mov
By animal954 in forum ffmpegX general discussionReplies: 2Last Post: 4th Mar 2009, 16:41 -
how to convert MP3 vbr to MP3 cbr?
By sumeshkri in forum AudioReplies: 2Last Post: 25th Aug 2008, 23:59 -
Anyone knows how to convert ASF / WMV to Mpeg2
By macuser1960 in forum ffmpegX general discussionReplies: 3Last Post: 9th Feb 2008, 16:38
