  1. i just downloaded a movie (XivD format) and when i try to play it in windows media player it gives me an error and i cant watch the movie.
    the error says something like this; the file may be formatted with an unsupported codec or your internet security settings isset to high on your computer etc
    what do i do? i have all the new codecs, divx 5.0 and the newest version of windows media player...
  2. Go to the link below to download vidomi - this
    should fix your problem. I think the nimo pack does not contain
    the latest xvid codec.
    http://www.vidomi.com/download.php?op=geninfovid&did1=1&did2=5
  3. True, Nimo doesn't give the latest Xvid codec... But it gives you one. I suggest you do what the smart man there says...
  4. thanks guys
