is there a way to burn bin files to a directory on your hard drive instead of putting them on cdr so i can watch them direct from my pc?
You can either extract the bin file content to a folder using isobuster,cdmage www.vcdhelp.com/tools#other
Or the best, mount the bin as a virtual cd-rom using virtual daemon www.vcdhelp.com/tools#other . Install virtual daemon and then you just open the bin and you have a virtual cd-rom unit on your computer exactly as you had burned the bin on a cdr/w. -
thanks baldrick .... i wish i'd known about this program before,it would have saved me a fortune in cdr's
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
bin files
By fredreed in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Nov 2009, 01:02 -
recover files from recycle bin
By Tbag in forum ComputerReplies: 5Last Post: 25th Jul 2008, 07:16 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
