Hi all,
I recently created a VCD using DVD Workshop. It consisted of 17 VCD 2.0 compliant movie clips, which I spread over 3 menus (6, 6, 5).
The VCD plays on my PC in WinDVD v4, but will not play at all on my Samsung 807 (home produced VCDs have never played on this). The VCD will play on my Philips DVDR890, but only up to a point.
The clips on menu 1 play fine, although instead of carrying onto the next clip, I am returned to the menu each time.
Five of the clips (1-5) on menu 2 play also. However, clip 6 on menu 2 and all 5 clips on menu 3 will not play when I press the corresponding button on my remote.
As I say, I have no problems in WinDVD. Is this a compatibility issue with my DVD players, or are there some techniques I need to know to make the VCD more compliant?
Thanks in advance.
Carts
It's hard to say but if it is a Philips player (they hold the patent to VCD), I would suggest that there is a problem with the authoring.
The best VCD authoring solution is probably VCDImager +/- a GUI (e.g., VCDEasy).
http://www.vcdimager.org
http://www.vcdimager.org/guides
http://www.vcdeasy.org
Regards.Michael Tam
w: Morsels of Evidence
Problems playing .mkv on a LG BD550
By Pipster2797 in forum Blu-ray RippingReplies: 15Last Post: 9th Jan 2017, 06:53 -
Problems playing Hi 8 tapes with my camera
By roscoe47 in forum Newbie / General discussionsReplies: 1Last Post: 12th Jul 2011, 11:43 -
VCD problems (playing using VLC; no menus in Media Player)
By pwhyles in forum Newbie / General discussionsReplies: 15Last Post: 17th Jan 2008, 13:16 -
MPEG playing problems
By Dave Knowles in forum Software PlayingReplies: 5Last Post: 14th Oct 2007, 07:31 -
Problems with recorded TV playing
By amir77a in forum Media Center PC / MediaCentersReplies: 4Last Post: 15th Jun 2007, 07:57
