i just converted a movie on tmpge and now the file is too big for the cd to burn i did this in a 1 disc template and made it 100% of the disc now its like 1 gig thanxs
Go look there, there is an excellent explanation how to do exactly what you want to do
http://www.vcdhelp.com/tmpgencedit.htm -
i dont want to split the movie i wanna put it on 1 disc before i converted the movie was only 699 mb after i converted it was 1.2 gb i converted it to put on 1 disc when i loaded into nero to burn it was far to big for a 80 mins cdr i never have this problem before .....i used a 1 cd template but this file has converted to twice the size as the original please you guys you must know the answer to this .....thanxs again........
It is normal for a DivX AVI (MPEG 4) to double in size when converting to a MPEG 1 (VCD)
Using a 1 disk template means your making a XVCD, and the quality is going to drop, how much it will drop will depend on how much your trying to cram onto one disk. If up until now your been converting 90 Min movies, but now have a much longer one, then you need to make the quality much lower to fit it on 1 disk.
Is it worth it ?, disks are so cheap, is the movie worth 2 disks ? good quality, or 1 disk bad quality. -
i get your point john i understand that (thanxs anyhow) but the problem is when i put it on to a 1 disc template SELECT 80 cdr or iso whatever to fit on 1 disc when i have finished converting and load into nero the file is too big for 1 disc i never had these probs before now theyre are suddenly happening.............thanxs again the point is i could squeeze on to 1 disc now i CANT.........THANXS FOR THE HELP AGAIN .IF IT WASNT FOR THESE FORUMS WE WOULD NEVER BE THIS FAR.
Winny22,
2 things:
1) you forgot to "unlock" the settings by loading unlock.mcf that is located in folder called "extra" in templates directory to be able to tweak your settings so that the file fits on 1 disk
OR
2) you forgot to choose NON-Standard VCD (XVCD) in the last tab of the Settings window - otherwise TMPGEnc will still encode the movie as if is is standard VCD and the file, therefore, will end up something like 1 gig.
Hope this helps
Output file is way bigger than input file in Virtualdub
By sasuweh in forum Video ConversionReplies: 31Last Post: 10th Oct 2013, 17:25 -
LCD Monitor Screen Size, bigger isn't really bigger?
By Des in forum ComputerReplies: 13Last Post: 27th Dec 2011, 14:13 -
ISO file bigger than original video_ts file.
By bbanderic in forum DVD RippingReplies: 8Last Post: 20th Feb 2010, 19:04 -
Bigger file with lower resolution after conversion???
By unplug in forum EditingReplies: 6Last Post: 20th Aug 2008, 16:09 -
AutoGK - Bigger file = better quality?
By kelemvor in forum DVD RippingReplies: 13Last Post: 8th Jan 2008, 22:15
