How can I record the audio soundtracks, songs, music directly from regular VHS video tape recorder into my notebook computer so I can get clear audio quality without any background noises?
Is there any software or any plug-in accessories that can help me in recording the audio soundtracks, songs, music directly from the regular VHS tape recorder into my notebook computer in mp3 or wav format?
Results 1 to 9 of 9
HI,
I'm new to this video world too but if you get the sound tracks onto your HD (I use AVRack) as a WAV then try DEPOPPER Version 2. It's Freeware and works rather well. Just get VERY aggressive with the Noise Suppression settings at first and then back down.
Again, it's freeware and easily found but if you like it then be sure to send in the suggested donation of $18.
Gil -
You could also record them from the line in, into www.goldwave.com (Also get MP3 plug-in) then if there is anything wrong, fix it with the many filters before saving to WAV or MP3
Thanks for the rely.
To member named Grappold,
I am an new user to these video/audio stuff.
Can you tell me what's HD & what's Avrac? What functions can they do?
Where can they be found? website address?
what's Depopper version 2 and where can it be found? -
Thanks for the rely,
To member named KingJohn,
I am a newuser.
Can you tell me what is a line-in? mp3 line-in?
Is it an added notebook computer accessory or a software I have to buy for the notebook computer? -
Sorry, spend some time in the help guides !!
Line in = the connection on your sound card -
Kingjohn,
I can hear music, sounds, songs when I play a CD on my computer.
I have volume control to adjust the sound volume.
do I need to buy any computer accessories such as plug-in cords...etc?
Does goldmine include mp3 plug-in software?
where can I get this plug-in or mp3 plug-in? -
Is there a way where I can connect the VHS video tape recorder audio out to my notebook computer in order to record the audio soundtrack,music & songs from the VHS video tape to my notebook computer?
I was wondering can I record the audio from the VHS tape by connection cables from VHS video recorder to my computer like recording vcr to vcr by audio & video cables? -
Gold Wave has MP3 plug-ins on the download page.
If you want to record the tracks from a CD, you can use gold wave to "Rip them" instead of recording them.
Tools > Cd audio extraction
If you wish to record from your notebook you need to use the socket on your sound card marked "line in"
Notebook PC
Sound out > Line In
VHS PC
Audio out (Scart or phoneo) > Line In
Can we record videos directly to compact flash in sony pd 177?
By vinnyjoseph in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 9th Mar 2011, 12:13 -
Capture and record video directly to DVD
By ruslenko in forum Capturing and VCRReplies: 8Last Post: 9th Oct 2010, 09:47 -
DVR machines that can record directly to an external HDD?
By ryanwayne in forum Capturing and VCRReplies: 0Last Post: 16th Sep 2009, 23:25 -
Is it possible to record directly to a computer?
By RevenantOne in forum Newbie / General discussionsReplies: 5Last Post: 14th Aug 2009, 15:05 -
Record (capture?) directly to the pc...not to tape first
By bobogs in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 3rd Jun 2009, 06:55
