Hi, I am thinking about buying TV recording software/hardware for my PC. I've done some research, but I really need you gurus opinions and advice.
OK,I would like to record TV shows with my PC, save as MPEG file, then burn into my CDs after cutting out commercials. I want to have a full-screen quality, not small frame.
Could you guys recommend any software/hardware that can fulfill my requrememts? Again, I really want to have good/professional quality one. How is the WinTV-PVR? Any advice or suggesstion?
My computer is Pentium 4 1.5 GHZ with WinMe. (40 GB) If it is possible, I would like to record tv everyday. I need some stable & good quality one.
Please enlighten me. Thanks in advance.
In all honesty, after trying a few *commercial* programs, I have found that VirtualDub is probably the best capture/encoding/editing application available. I am sure that many on this board will agree with me. You'll also need tmpeg to convert from .avi to mpeg. At least try them out before you dump hard earned $$$ into a commercial program. I get best results with tmpeg 12b.
As for hardware, I suggest you go out and pick an inexpensive ati or pinnacle capture card. You'd be suprised how well I capture with my ATI. High price is certainly not the determining *quality* factor with capture cards anymore. If you're in the U.S. try circuit city. suredeals.com has great prices on ati all in wonder cards.
<font size=-1>[ This Message was edited by: fugoff on 2001-08-16 13:12:26 ]</font>
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 12:11 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
FFmpeg - Removing commercial breaks from mpeg TV recording
By Chris_Smith in forum Video ConversionReplies: 0Last Post: 19th May 2009, 04:43 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
Converting AVI file to mpeg 2 question.
By ingeborgdot in forum Video ConversionReplies: 17Last Post: 7th Nov 2008, 21:49
