okay i have this file...
File Format: Audio-Video Interleaved (AVI)
Author: Microsoft Corporation
Web Site: www.microsoft.com
Content: Video and Audio
Duration: 46 min 13 sec
Data Rate: 679 kbps (ave)
Video Info: 352 x 208, 20 fps
Audio Info: 48000 Hz, 96.0 kbps, stereo
Video Format: Microsoft MPEG-4 Video V3
FourCC: "MP43"
Older MPEG-4 compressor shipped with Microsoft Windows Media Tools 4.
This format is identical to the DivX version 3 format.
If you change the FourCC code to "DIV3" it will play on the DivX codec
(www.divx.com).
Audio Format: MPEG Layer 3
Format ID: 0x0055
Author: Moving Picture Experts Group
Web Site: mpeg.telecomitalialab.com
This CODEC is distributed with MediaPlayer.
I wish to burn them into a vcd. Usually, i would let nero do all the shit encoding and trouble, but recently this file has annoyed me with error in encoding at 100% and 34%.
I have compiled a method i will use to convert avi to vcd, Please help me check for any wrong(s). thanks~
1) Load VirtualDub
2) Extract the Wav file (SAVE WAV) *not a normal wav*
3) Load TMPGenc
- NTSC
- Video File (2.AVI)
- Audio File (The previous one i extracted out from virtualdub)
4) Start Encoding.
but i was prompted "File "x:\<directory>\2.avi" can not open, or unsupported." when i tried to load the video file.
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 16:34 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 21:27 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Converting vfr-avi to cfr-avi that produced error in picture.
By Jo The Veteran in forum Video ConversionReplies: 27Last Post: 2nd Aug 2007, 00:41 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 00:22
