hi, when i burn with nero with an MPG file, it has to encode because i dont encode it correctly or whatever. this is fine, but is there any way to save the correctly encoded version on nero so that if i make 50 copies it doesnt have to encode each time? sounds simple huh? well then i hope yall can help!
---------rj
dr_em2001,
Your best place to start is in the "How To" section located on the left hand side of the page.Warning! I'm baaaaaaaaack -
give me a break, you act like im a newbie or something. i know what im doing, and the reason i asked in the forum is because i didnt want to spend an hour trying to find something that iv'e probably already read that may mention how to
I normally not let nero to re-encode. I just let it burn as is. All the times burnt disc played fine on DVD.
Hmm...you're asking a newbie question in a newbie forum but don't want to be considered a newbie? If you know what you're doing, than why is Nero not liking your MPG file?
Why not go back and spend an hour reading the how-to's here? That's how most of us have learned these things. If you did, then you might know to try encoding with TMPGenc and the desired template to make a compliant MPG that Nero will gladly accept.
meGUI Nero AAC encoding error
By ArtOfLosingMFZB in forum DVD RippingReplies: 4Last Post: 16th Aug 2010, 12:46 -
Nero Recode encoding problem
By goodmedo2003 in forum Video ConversionReplies: 4Last Post: 30th Apr 2009, 10:35 -
nero smart encoding
By m baqar in forum Authoring (DVD)Replies: 4Last Post: 27th Mar 2008, 05:13 -
nero 7 out of sync encoding
By sharky007 in forum Authoring (DVD)Replies: 1Last Post: 25th Jul 2007, 04:28 -
Question for Those Who are Familiar with Nero 6 or 7 on Encoding to MPEG-2
By wayney in forum Newbie / General discussionsReplies: 11Last Post: 13th Jun 2007, 19:35
