  1. I loaded my M2V and AC3 into SpruceUp. I made these files using this guide:
    http://www.digital-forums.com/dvd2dvdr/
    I went to Preferences and set them for NTSC and DVD-R/RW media. When I have everything ready, I go to Export, and the output is trying to write a PAL title set. What can I do?
    -J
    Apr 2002
    Australia
    Spruce up does not like you changing the DVD settings halfway through a project (i.e. after you create a new project or after importing files)
    Try changing the settings then go create a new project and import your files.
  3. Right on the money!
    Took a couple minutes, re-did the project, came out perfectly!
    Thanks!
    -J
    Apr 2002
    Australia
    no worries
