I have a commercially pressed VCD and due to an error in encoding on the part of the company, the audio is out of sync with the video. How can I correct this without using VitualDub to push the audio forward, then re-encoding? Is there an audio program that I can use to push just the audio forward (after de-muxing), then I can re-mux? PLEASE let me know. Thanks!
by "push the audio forward", i assume you mean you'd like to clip off some from the beginning, having the audio start just a tad (msecs) sooner. i've had a lot of success doing that very thing with a utility called MP3-Cutter. you just load the mp2 file, bump the start point up some (10 increments = 250ms), and save.
I'm not sure if I want it to start sooner or later, I need to experiment to find out which one. But is there a program that can do both (free or shareware)?
i've never used MP3-Cutter to add (start audio later if the video is lagging), just cut (start audio sooner when audio is lagging).
although a bit more time intensive, a much more accurate method i've used for synching audio/video is:
- load video stream in vdub
- load audio stream in sonic's sound forge (this converts the stream to WAV)
- find a spot in both streams that should be occurring at precisely the same time
- note the time in each stream
- edit the audio stream accordingly (cut or insert)
- save WAV and convert to mp2
- re-multiplex audio/video streams
this has provided me with THE most synchronized audio/video streams in an mpeg. i've even done this with some older XVCDs that were out of synch by just a teeny weeny bit, but just enough to bug you if you spot it once. after that you notice it all the time. i hate that.
taking the time out to edit the audio stream in those has produced much nicer XVCDs and a much more enjoyable viewing experience.
Making a multi-track audio CD from a commercial concert DVD ?
By MacPCConsultants in forum AudioReplies: 11Last Post: 2nd Jan 2012, 09:26 -
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 22:53 -
(MKV) Audio/Video synching problems after remuxing the same files I demuxed
By Sigma X Virus in forum Newbie / General discussionsReplies: 3Last Post: 9th Feb 2009, 16:27 -
Video/Audio synching problems.
By ericblair in forum DVB / IPTVReplies: 0Last Post: 26th Jan 2009, 19:38 -
synching m2v and wav audio - strange problem
By ecc in forum EditingReplies: 7Last Post: 20th Feb 2008, 05:22
