Hi just installed nimo light to see if that would help solve my problem with running an AVI movie, it didn't howeverwindows media player is now saying that in order for the movie to be played it needs the YUY2 codec can someone point me in the right direction as to where I can grab this from.
cheers
orion2
I believe huffyuv ( freeware ) installs a yuv->rgb translation filter.
In win98se you have to edit the system.ini drivers-drivers32
and point it to the Huffy codec if you want to override the default dll.
I believe the info comes with the codec
I am not using the huffy right now but mine looks like this:
VIDC.YUY2=MSYUV.DLL
I don't know how it looks in other win OS.There's not much to do but then I can't do much anyway. -
Thanks for replying but I still don't know where to get the codec from??
Any ideas?
thanks -
like snowmoon said .. try the huffyuv codec.
Just look on the panel at the left under OTHER TOOLS Codecs.There's not much to do but then I can't do much anyway. -
Yeah thanks I downloaded the huffyuv codec from tools and tried to install it, but it was asking fot the huffyuv.dll. Thia wasn't in the codec that I downloaded.
Can someone send me the dll file or tell me where to get it.
cheers
YUY2 vs RGB24 vs Y800
By 201flyer in forum Software PlayingReplies: 40Last Post: 28th Apr 2011, 06:11 -
Convert YUY2 to RGB
By jrivord in forum Video Streaming DownloadingReplies: 8Last Post: 19th Aug 2010, 10:21 -
YUY2 Codec for Quicktime?
By EZ-Fan in forum Software PlayingReplies: 1Last Post: 12th May 2009, 08:07 -
YUY2 Vs. UYVY Capture
By W_Eagle in forum Capturing and VCRReplies: 2Last Post: 11th Jul 2008, 10:15 -
Raw YUY2 to YV12 format?
By allyli2007 in forum ProgrammingReplies: 8Last Post: 2nd Jun 2007, 12:43
