What I am talking about is referring to DivX 5
I have noticed that some movies with lower resolution look better than other divx movies with lower resolution. Bitrate deals with audio quality correct? The kbps confuses me though. My DivX version of Gladiator is 1.2GB! It has a fairly normal resolution 640x272 but the kbps is 127. Is that why the large file size?
Any help or links to a divx glossary would be great.
KBPS refers to kilobits per second. This can stand for both video AND audio. What it means is more data is available to show the video or hear the audio. Sorta like more bandwidth on your internet line. The higher the bandwidth the faster the internet connection and in the case of movies, better video and audio quality. Hears how to calculate bitrate to file size.
Add the video bitrate to the audio bitrate. divide by 8. Thats how many kiloBYTES per second your movie takes up. Hears an example using a video clip with a 300kbps video rate and a 56kbps audio rate
300 + 56 = 356
356/8 = 44.5KBps
or 44.5 kilobytes per second of the movie
1 minute would eat up 2.67MB.A bird in the hand is worth a foot in the tush-Kelly Bundy -
Very True. If you DLL movies, you don't have to watch the size of the file that much, check the resolution... that will tell you much more
Some of those have high quality Video (High bitrate) but very low quality audio.. Great looking movies you can't hearOriginally Posted by DreamTFK
you can boost the audio, thank goodness...
Speaking of boosting the audio, I have a dvd rip of Casino and the audio sucks. How do I increase the quality, vdub?
Audio > full processing modeOriginally Posted by DreamTFK
Audio > Volume
But also
Audio > Compression > Codec > same as source > bitrate
Otherwise it saves it uncompressed, if your converting to VCD/DVD/SVCD later you can also increase the audio there.
You could also save it out
Audio > > full processing mode
Audio > conversion > 44.1Khz
SAVE WAV
Then use www.goldwave.com to edit (Gold wave will also load audio from an AVI)
But check your ripper program, they may be a setting in there ? -
I didnt rip it. It's a Kazaa download, If I had ripped it then it would be much better quality.Originally Posted by KingJohn
Ok well upping the volume works great but this is an mpg file not an avi file. Am I suppoed to put video on direct stream copy? Because I get this error when re-saving it. If I switch to video >> full processing mode, then the file size is huge.
"If I switch to video >> full processing mode, then the file size is huge. "
Video > full processing mode
Video > Compression > Codec > MP3 > Data rate
Would solve the size, however you said in this post
"What I am talking about is referring to DivX 5" so this cannot be a .mpg and must be an AVI.
Although Vdub will edit .mpg it can only save as AVI, so if you wish to keep it as a .mpg use TMPGEnc
"Speaking of boosting the audio, I have a dvd rip of Casino and the audio sucks. How do I increase the quality, vdub?"
If that is the file you are talking about, then in the ripping program it will have an audio gain when converting to mpeg
Help explaining 60i (30p sensor output)
By x2x3x2 in forum Newbie / General discussionsReplies: 7Last Post: 27th Jul 2011, 22:05 -
What do these video terms mean?
By mst in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jul 2011, 16:39 -
best converter and format in terms of quality output in ur opinion?
By FaisalKhan in forum Video ConversionReplies: 2Last Post: 2nd Jan 2011, 07:45 -
Which is better, LCD or Plasma TV in terms of pixelation?
By dzsoul in forum DVB / IPTVReplies: 51Last Post: 12th Jul 2009, 08:14 -
explaining copying speeds
By nobbydadog in forum Newbie / General discussionsReplies: 1Last Post: 30th Dec 2007, 04:19
