In studio, go into the video tab on the left side of the story board. Look at the different tabs inside, and find the sliders that let you adjust brightness/contrast/blur/color/hue/saturation/emboss.... and the one you want is MOSAIC.... be sure that is all the way to the left (setting should be 0).Originally Posted by Charlie Brown
I don't know for sure if this is the problem, but it does EXACTLY what you are describing. I can duplicate exactly what you describe by cranking up the MOSAIC slider...
Give it a look...
Results 31 to 34 of 34
Thanks everybody. Good suggestions, all worth trying. You are all a great bunch of guys. I am off to a wedding and will return after the weekend and test all your ideas. I hope some solve my problem. You are right, the hardware/software manufacturers like to make us believe that it's so easy that a child could do it. Ha!
Have a good weekend, everybody. -
crjackson
Thanks for your suggestion. What you describe works if you are capturing from a video source (VCR), you cannot alter these parameters when the source is DV. -
i had a similar problem playing back dv/avi files captured with a minidv camcorder, playback on the computer looked more like mpeg1, when these files should playback looking crytsal clear. i use windows media player to playback my files and found that there is a slider called "digital video (dv) settings (goto tabs tools/options/performance) that can adjust the playback quality. by moving this slider fully to the right i was able to correct my faulty dv/avi playback.
DV capture quality sucks
By cooldude859 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 36Last Post: 28th May 2008, 16:07 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05 -
Problems with Capture Quality
By drxpsp9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 25th Jul 2007, 23:53 -
How To Capture in better quality Help??
By Force21 in forum Newbie / General discussionsReplies: 1Last Post: 27th Jun 2007, 17:46 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 20:42
