Alright, I do not currently have a DVD burner, but I do have a CD burner. I've managed to capture some video (home movies, TV shows, etc) that I want to archive - I've created VCD and SVCD discs of this content (using TMPGenc to encode), but everyone tells me that these MPEG files cannot be re-used later on DVD media...
So - my question for the forum is this: Is there some format I can encode by videos in now that I can burn on CD-ROM and play in my DVD player (VCD, SVCD, or something) that I can later copy over to DVD media when I get a DVD burner?
Thanks!
-Zak
You can make an xVCD with a resolution of 352x480 that can later be put on DVD. This is a legal low resolution for DVD
Alright... 352x480 at what bitrates? MPEG-1 or MPEG-2? Is there a template for this format somewhere that I can use with TMPGEnc?
Thanks a lot!
-Zak -
mpeg2 is dvd. Basically you can use as high of bitrate that you want or that your dvd player will handle. DVD bitrates are much higher tha VCD. (6000 vs. 1150)
I don't think 352x480 @ MPEG-1 is a valid DVD videostream
You can have 352x480 MPEG -2 or 352x240 MPEG-1
I think 352x480 (576 for PAL) MPEG-2 @ CBR 2520, AUDIO 224, 48Hz
will give the least problems when transfering to DVD-r later on. It
may not. however, play correctly on your current DVD player. You will
have to test.
You might want to stick with 352x240(288 pal)
@ CBR 1150, 44.1Hkz stereo at 224 kbits. When transfering this to DVD, all you need to do is upsample audio to 48Hkz and remux.
DVD authoring software requires video streams with different GOP
settings etc. To make sure, maybe d/l a couple of DVD authoring
demos and test.
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 09:33 -
CPRM compatible DVD -RW
By tbl35 in forum Newbie / General discussionsReplies: 8Last Post: 6th Oct 2009, 13:13 -
Vista compatible mpeg joiner where 2 clips have diff dimensions?
By wetcamelfood in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2009, 14:14 -
Compatible Burner for Womble's "MPEG Video Wizard DVD"?
By cyberboy in forum Authoring (DVD)Replies: 3Last Post: 4th Jul 2008, 23:25 -
VHS, Hi-8 transfer to DVD and DVD-ROM MPEG file online service?
By DeanPk in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 15:30
