I want to change the bitrate on a mpeg2 file to make it slightly smaller.
What is the best program to do this.
TMPEG does not change it when loading the mpg file and then reencode with changed bitrate.
My only way so far is to reencode to avi (divx) and then use TMPEG with lower bitrate.
Anyone knows of a program that can convert mpg to mpg with a different bitrate???
but how??
like I said. When I enter the vid in the main window and change the bitrate in the settings, nothing happens. the size and the bitrate stay the same... -
well it takes some time to re-encode ... its not a instant thing .
did you follow the guides here? -
You can use a custom template to set any bit rate you want in TMPGenc. If the selection is greyed out then load the unlock template on top of the DVD template & then you can change to your hearts content.
Panasonic DMR-ES45VS, keep those discs a burnin' -
try rempeg2, it is a utility to lower bitrates. tmpgenc will give you
a better output though. Change the tmpgenc bitrate settings AFTER you have
loaded the source video.
changing audio bitrate with ffmpeg
By wallywalters in forum Video ConversionReplies: 4Last Post: 11th Feb 2011, 05:45 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 19:45 -
Changing AVI Bitrate!
By Ace-Of-Spades in forum Newbie / General discussionsReplies: 5Last Post: 8th May 2008, 12:23 -
Changing AC-3 Bitrate
By kotton in forum AudioReplies: 5Last Post: 1st Sep 2007, 23:29 -
By kotton in forum Video ConversionReplies: 2Last Post: 1st Sep 2007, 22:05
