  1. Anonymous
    Guest
    I have a movie on my HD, separated into chapters, still in .vob
    format. I want to author these to DVD, but none of the burning
    programs I've tried (Prassi and MyDVD) will accept the .vobs.
    Here's what I have:
    I ripped a DVD to the HD by chapters. So I have a directory like
    this.
    Scene 1.vob 387,848 KB
    Scene 2.vob 380,283 KB
    Scene 3.vob 130,516 KB
    Scene 4.vob 224,708 KB
    Scene 5.vob 79,000 KB
    Scene 6.vob 125,170 KB
    Scene 7.vob 118,240 KB
    Scene 8.vob 61,418 KB
    Scene 9.vob 5,044 KB
    I now have a DVD-R burner and want to burn these files. The
    problem is I need an .ifo file. Is there a program, that can
    create an ifo just by looking at the files if i tell it those
    are the chapters?
  2. IFO edit with create IFO files for you.
  3. Member wulf109's Avatar
    Jul 2002
    Ifoedit will create Ifo's for you. Rename your vob's VTS_01_1.VOB,etc.
    Play it and make sure it's playing in the corect order. You may need to use VOBedit to join them and correct the ID's.
